mutual exclusion checkboxes
2020
08-21-2023 05:51 AM
Daniel4
Hi
I want to implement two check boxes there are mutual exclusion. If box one are checked to true, box two must automatic turn to false. I have the two checkboxes in a dockpan.
This is what I have so far.
xaml:
 <CheckBox
    Margin="5"
    Style="{DynamicResource Esri_CheckboxToggleSwitch}"
    Name="CheckBox_One"
    IsChecked="{Binding IsCheckedBoxOne}">
    <TextBlock>
    <Run Text="BoxOne"/>
    </TextBlock>
    </CheckBox>
<CheckBox
     Margin="5"
     Name="CheckBox_Two"
     IsChecked="{Binding IsCheckedBoxTwo}">
     <TextBlock>
     <Run Text="BoxTwo"/>
     </TextBlock>
</CheckBox>
c#:
private bool _isCheckedBoxOne;
private bool _isCheckedBoxTwo;
public bool IsCheckedBoxOne
         get { return _isCheckedBoxOne; }
         set
                SetProperty(ref _isCheckedBoxOne, value);
public bool IsCheckedBoxTwo
            get { return _isCheckedBoxTwo; }
            set
               SetProperty(ref _isCheckedBoxTwo, value);
How to implement the logic?
Wolf
by Esri Regular Contributor
If you implement your checkbox logic in the viewmodel as @GKmieliauskas  suggests you have to prevent recursion when you set the counter property.  Here is my suggestion (i attached a sample solution)
private bool _isCheckedOne;
    private bool _isCheckedTwo;
    public bool IsCheckedOne
      get { return _isCheckedOne; }
      set
        SetProperty(ref _isCheckedOne, value);
        if (IsCheckedTwo == IsCheckedOne)
          // prevent recursion
          IsCheckedTwo = !IsCheckedOne;
    public bool IsCheckedTwo
      get { return _isCheckedTwo; }
      set
        SetProperty(ref _isCheckedTwo, value);
        if (IsCheckedOne == IsCheckedTwo)
          IsCheckedOne = !IsCheckedTwo;
GKmieliauskas
There is no logic implemented in your code between IsCheckedOne and IsCheckedTwo properties.
         set
                _isCheckedBoxTwo = !_isCheckedBoxOne;
                // Generate notification message here to update _isCheckBoxTwo, it could differ from that sample
               OnPropertyChanged("IsCheckedBoxTwo");
            set
                _isCheckedBoxOne = !_isCheckedBoxTwo;
                // Generate notification message here to update _isCheckBoxOne, it could differ from that sample
               OnPropertyChanged("IsCheckedBoxOne");
It is enough one property for both controls, but you need to use boolean inverting converter in second property binding.
Question like yours is not a scope of ArcGIS Pro. It is WPF part.
Wolf
      set
      set
Daniel4
Hi, thanks for the answer both of you.
I try both, and it works for me.
@Wolf I tried the sample solution, but its target AGO 3.2 🙂
Daniel4
I changed the target in the daml-file and can run the souluton.
Wolf
The attached solution (should work with 3.0) has two options: one with a code-behind implementation and one with a XAML based implementation that is using a value converter.
