Label by attribute
1335
12-21-2022 05:40 AM
Daniel4
Hi Everbody
I am trying to label a FeatureLayer with values from an attribute, but somehow it fails. I have calculated the z-value and want to label that, but for some reason it label another attribute.
In the CIMLabelClass I define the Expression to be the 'zValue' attribute:
var labelFeatureLayer = new CIMLabelClass
                            Name = "labelFeatureLayer",
                            ExpressionEngine = LabelExpressionEngine.Arcade,
                            Expression = "$feature.zValue",
                            TextSymbol = SymbolFactory.Instance.ConstructTextSymbol().MakeSymbolReference(),
                            Visibility = true
                        var lyrDefn = fcLayer.GetDefinition() as CIMFeatureLayer;
                        var listLabelClasses = lyrDefn.LabelClasses.ToList();
                        listLabelClasses.Add(labelFeatureLayer);
                        lyrDefn.LabelClasses = listLabelClasses.ToArray();
                        fcLayer.SetDefinition(lyrDefn);
                        fcLayer.SetLabelVisibility(true);
But its just showing a different attribute (in this case its the objectid)
GKmieliauskas
I think you need to switch off visibility for other existing label classes. Look at Esri community sample LabelLineFeatures
                //Turn off all the label classes except this one
                foreach (var lc in listLabelClasses)
                    lc.Visibility = lc.Name == "labelFeatureLayer" ? true : false;
Wolf
by Esri Regular Contributor
The following snippet worked for me:
protected override async void OnClick()
  var fcLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(fl => fl.Name == "TestPoints").FirstOrDefault();
  await QueuedTask.Run(() =>
    List<CIMLabelClass> newLabels = new List<CIMLabelClass>()
    { new CIMLabelClass
        Expression = "Geometry($feature).z",
        Visibility = true
    lyrDefn.LabelClasses = newLabels.ToArray();
@GKmieliauskas  is correct as there can be multiple labels with visibility.   The snippet above removes all but the new label from the array of labels.
Daniel4
Hi, thanks.
I tried with your code @Wolf but ArcGIS Pro doesn't  show the label.
The label tab dont show the new label class:
But if I manual in ArcGis Pro create a label class (eg. 'test'), suddenly the new label class appires:
Do I need to delete some Label Classes before? Or do I need do to something with 'Class 1'?
