Inserting GUIDs into a file geodatabase
2592
07-06-2020 05:46 AM
CARNELL_DEVTWO
I am reading data from a database that is incompatible with ArcGIS Pro into an ESRI geodatabase using the .Net SDK. The database stores primary keys as GUIDs e.g. {e372ad91-9e24-4054-9454-5bb31657f2db} which is the same format as a GUID field in an ESRI file geodatabase (.gdb).
However, if I try to write these GUIDs to a file geodatabase, I get an exception at the line where I add the GUID field to the row buffer:
NameValueType
$exception{"A general error when something is wrong with a Field."}ArcGIS.Core.Data.GeodatabaseFieldException
Are GUIDs in file geodatabases handled in a special way? I can't seem to write in new ones generated outside of ArcGIS Pro.
Thank you very much in advance.
Here is the basic outline of my code and a mock feature table to illustrate my question:
FacilityIDNameOwnTypeGUIDField
1Griffith ParkMunicipal{e372ad91-9e24-4054-9454-5bb31657f2db}
2LondonMunicipal{zyxqad91-7g76-9999-9434-5aa31657f2db}
3IndiaMunicipal{abc1ad91-9e24-8888-1234-5aa12345f2db}
public async Task CreatingAFeature() {
         string message = String.Empty;
         bool creationResult = false;
         await ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
            using (Geodatabase geodatabase = new Geodatabase(new Geodatabase(new FileGeodatabaseConnectionPath(new Uri("filePath")));))))
            using (FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>("FeatureClassName"))
               //declare the callback
               EditOperation editOperation = new EditOperation();
               editOperation.Callback(context =>
               FeatureClassDefinition facilitySiteDefinition = featureClass.GetDefinition();
               int facilityIdIndex = facilitySiteDefinition.FindField("FACILITYID");
               using (RowBuffer rowBuffer = featureClass.CreateRowBuffer())
                  // Fill fields of row buffer
               rowBuffer["facilityId"] = 4;
               rowBuffer["NAME"] = "Griffith Park";
               rowBuffer["OWNTYPE"] = "Municipal";
                /* The line that throws the exception.
                Commenting out this line makes everything run fine
                I generate a new GUID here for the sake of the example.
                Trying to write a GUID from the dataset, or writing the GUID
                as a string also throws an exception.
                rowBuffer["GUIDField"] = Guid.NewGuid();  // The line that throws the exception.
          ... code continues
RichRuh
It looks like calling Guid.NewGuid() generates a global ID without braces around it.
Try this instead:
rowBuffer["GUIDField"] = "{" + Guid.NewGuid().ToString() + "}";
--Rich
RichRuh
Try this instead:
--Rich
CARNELL_DEVTWO
Hi Rich,
That works perfectly, thank you very much.
