How to uninstall a Managed Configuration?
3340
6
02-28-2020 01:54 AM
BarbaraSchneider2
I haven't found out how to correctly uninstall an ArcGIS Pro Managed Configuration.
When ArcGIS Pro is open, and I go to Project - Add-In Manager, no Add-In is detected.
So I deleted the configuration file on C:\Users\<UserName>\Documents\ArcGIS\AddIns\ArcGISPro\Configurations. But I guess this is not the correct way.
GKmieliauskas
Hi Barbara,
You need to delete ConfigurationFolders registry key. If you do not delete registry key, ArcGIS Pro could search in your documents Add-ins folder, where config installation is located as all ArcGIS Pro add-ins installations.
I have not tried to do it manually or by code. I use VS Installer project. It makes all steps automatically. You just need to set up all actions in the project.
You need to download it separately from Visual Studio
GKmieliauskas
Hi Barbara,
There is a record in registry about configuration file: More info here:
ArcGIS Pro Registry Keys · Esri/arcgis-pro-sdk Wiki · GitHub Note: from 3.0 Esri decided to change that setting.
We use registry editor settings in the install project.
BarbaraSchneider2
Hi Gintautas,
I'm not sure whether I understand your answer right. What I do now:
- To install my managed configuration, I add an installation folder path in the registry in ConfigurationFolders. I then copy the file <MyConfig>.proConfigX to this installation folder.
- To uninstall my managed configuration, I just manually delete the file <MyConfig>.proConfigX in this installation folder.
GKmieliauskas
Hi Barbara,
BarbaraSchneider2
Hi Gintautas,
thank you. Now I understand, I have to create an installer. I already have InstallShield Express installed.
BarbaraSchneider2
Hi Gintautas,
do you use InstallShield to create an installer for the managed configuration? If yes, I would like to ask you a question concerning InstallShield.
GKmieliauskas
Hi Barbara,
Sorry. We use Visual Studio Installer which by default was in previous versions of Visual Studio. It goes by separate install now.
Our installation project was started with first ArcMap version and VS6. It contains many different code and data files so we still using modified copy of setup project for ArcGIS Pro too.
