How to programmatically activate the edit tools in arcpro sdk
2416
10-26-2024 12:49 PM
Gurunara
would like to activate:
1) Create feature
2) Modify feature, and in particular the Move option
3) Delete feature
tools under the Edit tab, programmatically for a specific feature layer, and subscribe to the edit completion events.
Is this possible in arcpro sdk?
2 Solutions
GKmieliauskas
Use GetPlugInWrapper Method—ArcGIS Pro. To find tool reference id move mouse over the tool.
GKmieliauskas
I think, you can't select template directly from Create Features pane. But your workflow could be like in sample below:
        protected async override void OnClick()
            await QueuedTask.Run(() =>
               // Find layer you will work with
                var featLayer = MapView.Active.Map.FindLayers("Poly1").First();
                // Get all templates and then select template you need or use GetTemplate if you know template name
                var editTemplates = featLayer.GetTemplates();
                if (editTemplates != null && editTemplates.Count > 0)
                    var editTemplate = editTemplates[0];
                    // Activate default tool
                    editTemplate.ActivateDefaultToolAsync();
GKmieliauskas
Gurunara
Works...
Gurunara
is there a way to programmatically select a template once the Create Feature tool is activated?
GKmieliauskas
