How to obtain button id on click event?
1883
10-04-2018 07:25 AM
RomanTrojan
I would like to retrieve button id of Config.daml from c# OnClick event without fixed coding:
<controls>
   <button id="ButtonID_TS1" className="ModuleID_TestAddIn:OnCustomButtonClick_StateID_1"
internal static void OnCustomButtonClick_StateID_1()
string ButtonID = ?   // how to obtain button id? --> "ButtonID_TS1";
I am studying arcgis-pro-sdk/wiki/ProConcepts-Framework with arcgis-pro-sdk-community-samples but cannot find appropriate method.
Having ButtonID I am able to get another button parameters using ArcGIS.Desktop.Framework - FrameworkApplication.GetPlugInWrapper(ButtonID) or any custom parameters applying <categories> with <content> using Categories.GetComponentElements and component.ReadAttribute functions.
UmaHarano
Hi Roman
You can get the button's ID directly like this:
internal class Button1 : Button
        protected override void OnClick()
            var buttonID = this.ID;
Thanks
Uma
RomanTrojan
Thank you, Ulma
Declaring my first button I have skipped to the issue with delegate command.
Stepping back to the Button class this.ID works fine.
But calling delegated void procedure on Module class there is no "this" constructor regarding button?
