How to load abbreviation dictionary
1963
10-11-2018 12:28 AM
servicesigu
I want to load abbreviation dictionnary from a table with ArcGisPro sdk, when a new map is added to a project. I dont find any way (snippset) to do this.
I done in it with the ArcObjects (for Arcmap) some years ago.
Could someone help me ?
Thanks.
UmaHarano
Hi
It is a two step process to work with Abbreviation Dictionary. You first have to create the dictionary and add it to the Map definition and then apply the dictionary to a specific layer.
This method below creates a dictionary and adds it to the Active map's definition:
public void LoadDictionary()
            //Get the map's defintion
            var mapDefn = MapView.Active.Map.GetDefinition();
            //Get the Map's Maplex labelling engine properties
            var mapDefnPlacementProps = mapDefn.GeneralPlacementProperties as CIMMaplexGeneralPlacementProperties;
            //Define the abbreaviations we need in an array
            List<CIMMaplexDictionaryEntry> abbreviationDictionary = new List<CIMMaplexDictionaryEntry>
                new CIMMaplexDictionaryEntry {
                Abbreviation = "Hts",
                Text = "Heights",
                MaplexAbbreviationType = MaplexAbbreviationType.Ending
                    Abbreviation = "Ct",
                    Text = "Text",
                //etc
            //The Maplex Dictionary - can hold multiple Abbreviation collections
            var maplexDictionary = new List<CIMMaplexDictionary>
                new CIMMaplexDictionary {
                    Name = "NameEndingsAbbreviations",
                    MaplexDictionary = abbreviationDictionary.ToArray()
            //Set the Maplex Label Engine Dictionary property to the Maplex Dictionary collection created above.
            mapDefnPlacementProps.Dictionaries = maplexDictionary.ToArray();
            //Set the Map defintion
            MapView.Active.Map.SetDefinition(mapDefn);
Second step, apply a specific abbreviation dictionary in the Map Definition to the layer:
var featureLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().First();
            QueuedTask.Run( () => {
                //Creates Abbreviation dictionary and adds to Map Defintion
                LoadDictionary();
                //Get the layer's definition
                var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
                //Get the label classes - we need the first one
                var listLabelClasses = lyrDefn.LabelClasses.ToList();
                var theLabelClass = listLabelClasses.FirstOrDefault();
                //Modify label Placement props to use abbreviation dictionary
                CIMGeneralPlacementProperties labelEngine = MapView.Active.Map.GetDefinition().GeneralPlacementProperties;
                theLabelClass.MaplexLabelPlacementProperties.DictionaryName = "NameEndingsAbbreviations";
                theLabelClass.MaplexLabelPlacementProperties.CanAbbreviateLabel = true;
                theLabelClass.MaplexLabelPlacementProperties.CanStackLabel = false;
                //Set the labelClasses back
                lyrDefn.LabelClasses = listLabelClasses.ToArray();
                //set the layer's definition
                featureLayer.SetDefinition(lyrDefn);
Uma
UmaHarano
Hi
                Text = "Heights",
                    Text = "Text",
                //etc
                LoadDictionary();
Uma
servicesigu
That's really what I needed.
Thanks a lot.
