How do I create a dialog that gives users the option of creating a new temporary feature class (polygon, polyline, points, multipart) or shapefile?
1404
02-26-2019 10:09 PM
ShannenLeong
I'm trying to build a button that upon clicking, gives users an option to either create a temporary feature class or a shapefile.
If the user selects the feature class, it gives him the option to choose the type of layer (polygon, polyline, point or multipart). Then it allows the user to name the layer created or the shapefile created if the user chooses otherwise.
ShannenLeong
Temporary feature class as in when created, it is stored in a scratch geodatabase.
MikeRatcliffe
Here is what I have in C# Windows Form that shortcuts the user to the built-in geoprocessing tool "create feature class" with some tweaks to the input values.  My users want a shapefile.  This sample provides a "starting point" for reference to be used in an add-in button, or in a custom Windows Form.
(Resulting inputs in the geoprocessing tool attached.)
private void Create_Shp_Click(object sender, EventArgs e)
            if (!(Directory.Exists(GVar.DL + @"GISdata\My_Shapefiles\")))
                try
                    new FileInfo(GVar.DL + @"GISdata\My_Shapefiles\").Directory.Create();
                catch (Exception)
                    MessageBox.Show(GVar.DL + @"GISdata\My_Shapefiles\ does not exist.", " Missing Outpath Folder",
                        MessageBoxButtons.OK,
                        MessageBoxIcon.Warning,
                        MessageBoxDefaultButton.Button1,
                        MessageBoxOptions.DefaultDesktopOnly);
                    return;
            string out_path = GVar.DL + @"GISdata\My_Shapefiles\";
            string out_name = "my_shapefile.shp";
            var param_values = Geoprocessing.MakeValueArray(out_path,out_name);
            Geoprocessing.OpenToolDialog("CreateFeatureclass_management", param_values);
