How do I add filename, filter in saveitemdialog
1420
06-04-2020 09:21 PM
by Anonymous User
Not applicable
Hi Guys,
I am using this code.
SaveItemDialog tmpDestination = new SaveItemDialog()
                Title = "ASCII Output file name",
                DefaultExt = "txt",
                Filter = "*.txt"
            if (tmpDestination.ShowDialog() == true)
Normally with savefileDialog, I can use FileName property to add default file name for user, Is there any way in saveitemdialog?
And When I add Filter property, it display like "Default" in file extension below,  how to make it obvious like txt extension?
UmaHarano
There is a built in browse dialog filter for text files you could use.  Like this:
      var txtFilter = BrowseProjectFilter.GetFilter("esri_browseDialogFilters_textFiles_txt");
      SaveItemDialog saveTxtFileDialog = new SaveItemDialog()
        Title = "Save Txt File",
        InitialLocation = @"C:\Data\",
        BrowseFilter = txtFilter,
        OverwritePrompt = true
      bool? result = saveTxtFileDialog.ShowDialog();
Or you could make your own filter to use like this:
var txtFilter = BrowseProjectFilter.GetFilter("esri_browseDialogFilters_browseFiles");
      txtFilter.FileExtension = "*.txt;";
      txtFilter.BrowsingFilesMode = true;
      txtFilter.Name = "Txt files (*.txt;)";
by Anonymous User
Not applicable
Thank Uma Harano‌,
It help for filter dropdown default, but How shall I add default file name in name textbox?
 string initialLocation = ZetaLongPaths.ZlpPathHelper.Combine(Project.Current.URI, this.SelectedLayer.Name + "_Ascii.txt");
            txtFilter.FileExtension = "*.txt";//restrict to specific extensions as needed
            //Specify a name to show in the filter dropdown combo box - otherwise the name will show as "Default"
            txtFilter.Name = "Text Files (*.txt)";
                AlwaysUseInitialLocation = true,
                InitialLocation = initialLocation,
