Getting feature classes in feature dataset
5491
5
06-25-2020 05:36 PM
AlexZlotin1
Given a geodatabase and a feature dataset name, what is the proper way to get the names of all feature classes contained in the feature dataset? I can get the list of FeatureClassDefinitions of all feature classes in the geodatabase, open each feature class, call GetFeatureDataset method and see if the feature dataset name of the feature class  matches the input feature dataset name. This looks like a very costly operation though. Thanks.
CharlesMacleod
Hi Alex,
Look here...
ProSnippets Geodatabase Obtaining List of Defintions from Geodatabase
ProSnippets Geodatabase, Obtaining related definitions from geodatabase
piecing the bits together gives you what you want
//From the snippets...
IReadOnlyList<FeatureDatasetDefinition> featureDatasetDefinitions = geodatabase.GetDefinitions<FeatureDatasetDefinition>();
bool electionRelatedFeatureDatasets = featureDatasetDefinitions.Any(definition => definition.GetName().Contains("Election"));
...and...
FeatureDatasetDefinition featureDatasetDefinition = geodatabase.GetDefinition<FeatureDatasetDefinition>("LocalGovernment.GDB.Address");
IReadOnlyList<Definition> datasetsInAddressDataset = geodatabase.GetRelatedDefinitions(featureDatasetDefinition, DefinitionRelationshipType.DatasetInFeatureDataset);
//put it together and you get...
IReadOnlyList<Definition> fdsList = gdb.GetDefinitions(DatasetType.FeatureDataset);
//get all the feature classes...
foreach (var fdsDef in fdsList) {
    var defsInDataset = gdb.GetRelatedDefinitions(fdsDef, DefinitionRelationshipType.DatasetInFeatureDataset);
    foreach (var def in defsInDataset) { //Or use LINQ .Where( d => d.DatasetType ...
       if (def.DatasetType == DatasetType.FeatureClass)
         ... etc ...
by Anonymous User
Not applicable
Hi Alex Zlotin‌,
You could run a quick Python script once you set your workspace to your feature dataset. See links below.
ListFeatureClasses—Help | ArcGIS Desktop
ListFeatureClasses—ArcPy Functions | Documentation
Cheers,
AlexZlotin1
Please note that I am trying to achieve this in Pro SDK, not Python.
by Anonymous User
Not applicable
Ah my apologies Alex Zlotin‌ missed your tag!
Victor Tey May have done some work in the Pro SDK space I’ve tagged him.
CharlesMacleod
Hi Alex,
Look here...
...and...
         ... etc ...
AlexZlotin1
Thanks Charles! I saw the snippet but overlooked the GetRelatedDefinitionsMethod.
