Get Installed ArcGIS Pro Version
1180
11-07-2018 07:12 AM
MKa
How do I get the version of ArcGIS Pro that is installed.  We need to manage which version is installed on our users machines.  Our configuration needs to be tested on all versions of pro that is released.  So we need to get the exact version that a user has installed on their computer and alert them as to a change they might need to do.
//This returns "2.2.0.0"???
string ArcGISProVersionLookup = System.Reflection.Assembly.GetEntryAssembly().GetName().Version.ToString();‍‍
This code only seems to return 2.2.0.0, but I want 2.2.3 like below on the About page
MKa
That was very helpful.  I am able to get the Versions of both the Installed ArcGIS Pro and the Installed .proConfigX version with the following.  You get the ArcGIS Pro version from the GetEntryAssembly() and the  addin/proconfigX version from the GetExecutingAssembly()
//ArcGIS Pro Version (GetEntryAssembly)
public static string GetArcGISVersionInstalled
            get
                string returnVersion = "";
                    Assembly asm = Assembly.GetEntryAssembly();
                    if (asm != null)
                        FileVersionInfo fvi = FileVersionInfo.GetVersionInfo(asm.Location);
                        if (fvi != null)
                            returnVersion = String.Format("{0}.{1}.{2}", fvi.ProductMajorPart, fvi.ProductMinorPart, fvi.ProductBuildPart);
                return returnVersion;
//addin/proconfigX Version (GetExecutingAssembly)
public static string GetAddinVersion
            get
                    Assembly asm = Assembly.GetExecutingAssembly();
                    if (asm != null)
                        if (fvi != null)
                            returnVersion = String.Format("{0}.{1}.{2}.{3}", fvi.ProductMajorPart, fvi.ProductMinorPart, fvi.ProductBuildPart, fvi.ProductPrivatePart);
UmaHarano
You could get the File version of ArcGISPro.exe like this:
string fileVersion = FileVersionInfo.GetVersionInfo(Assembly.GetEntryAssembly().Location).FileVersion;
MKa
            get
                    if (asm != null)
                        if (fvi != null)
            get
                    if (asm != null)
                        if (fvi != null)
