End of QueuedTask
1704
01-03-2018 12:17 PM
BrianBulla
Honored Contributor
In my code I am running some code in a QueuedTask.  After the QueuedTask code, I have some more code that seems to be getting run similtaneously to the QueuedTask, which is causing problems.
How do I stop the code from progressing until the QueuedTask is complete??
QueuedTask.Run(() =>
   //some code
); //end of QueuedTask
//more code down here, that seems to run while things are still processing in the QueuedTask
foreach()
   //included here is code that modifies a Windows Form that cannot run inside the QueuedTask, but needs to wait for the    QueuedTask to complete before running
etc.
Thanks!
SteveVan_Esch
You can use the await operator
    private async Task Foo()
      await QueuedTask.Run(() =>
SteveVan_Esch
BrianBulla
Honored Contributor
Thanks Steve.  Here is what I finally did to get things working:
async private void ReloadFields()
                    //code here
                //More code here
