EditOperation not getting added to undo stack
2237
07-27-2022 07:23 AM
BrettWaddingham
I'm creating a tool in ArcGIS Pro 3.0 that will duplicate selected features to a point that is clicked on the map.  The process works fine, but does not get added to the undo stack.
For example, I create 3 line features, selected all 3 features, Use my tool (click on map, those 3 features are duplicated with their combined center being on the point that I clicked).
If I were to click 'undo', this undoes my duplicate AND the last line I had created (leaving me as though I'd only created 2 lines).
RichRuh
Chained edit operations are typically used when the results of one call to Execute are needed for a subsequent call.  Maybe I'm missing something, but that doesn't seem to be the case here.
Could you try restructuring the code like this:
Create an edit operation
For each feature in the selection set
Create a copy, and call editOp.Create
Call editOp.Execute once at the end
RichRuh
Hi Brett,
Just to confirm- you're using the EditOperation class to duplicate the features, right?  Could you send us the EditOperation code that you use in your tool?
--Rich
BrettWaddingham
                //edit operation
                var edOp = new EditOperation();
                //edOp.ExecuteMode = ExecuteModeType.Sequential;
                edOp.Name = "Copy Features Tool";
                edOp.EditOperationType = EditOperationType.Long;
                edOp.SelectModifiedFeatures = false;
                edOp.Execute();
                //For each feature in selectedFeatures, get the specific OID for that feature
                //then, add it to the oIDs list
                foreach (var item in allSelectionSetValues.First())
                    var specificValue = item;
                    var duplicateFeatures = edOp.CreateChainedOperation();
                    duplicateFeatures.Name = "Duplicate Features";
                    var gadgetInsp = new Inspector();
                    gadgetInsp.Load(layer, specificValue);
                    var geom = gadgetInsp["SHAPE"] as Geometry;
                    geomList.Add(geom);
                    var rtoken = duplicateFeatures.Create(gadgetInsp.MapMember, gadgetInsp.ToDictionary(a => a.FieldName, a => a.CurrentValue));
                    if (duplicateFeatures.Execute())
                        oIDs.Add((long)rtoken.ObjectID);
Here is the portion of code that has to do with the edit operation after the mouse is clicked.
Wolf
by Esri Regular Contributor
Check the return value of edOp.Execute(); It might be false.  Also check if edOp.IsEmpty is set.  But yes I agree with Rich i don't see the need for a chained operation here either.
RichRuh
BrettWaddingham
I think I've got it figured.  I had to re-arrange the code a bit.  After duplicating each selected feature, I was doing a .Move (to clicked location).
//edit operation
                    geomList.Add(geom);
                    var rtoken = edOp.Create(gadgetInsp.MapMember, gadgetInsp.ToDictionary(a => a.FieldName, a => a.CurrentValue));
                    rowTokens.Add(rtoken);
                edOp.Execute();
