EditOperation.ExecuteAsync runs, but edits aren't saved
2070
05-19-2022 02:00 PM
KenBuja
MVP Esteemed Contributor
I am running an EditOperation in my add-in, but after I call the ExecuteAsync method and look at the Edit tab, the Save button is activated. This is a problem, since the next step in the process is to run a dissolve on the edited layer. I get the error message that the dissolve cannot run since the layer is being edited.
In this code, I'm modifying two fields and saving the edits. Why aren't they being properly saved?
        QueryFilter queryFilter = new QueryFilter { WhereClause = "1=1" };
        EditOperation editOperation = new EditOperation();
        Inspector inspector;
        editOperation.ShowProgressor = true;
        await QueuedTask.Run(() =>
          using (RowCursor rowCursor = featureClass.Search(queryFilter, false))
            while (rowCursor.MoveNext())
              using (Row record = rowCursor.Current)
                inspector = new Inspector();
                inspector.Load(record);
                inspector["PS_Count"] = 1;
                if (geometryType == GeometryType.Polygon)
                  var feature = (Feature)record;
                  inspector["PS_Area"] = GeometryEngine.Instance.GeodesicArea(feature.GetShape());
                editOperation.Modify(inspector);
        try
          bool result = await editOperation.ExecuteAsync();
          if (!result) message = editOperation.ErrorMessage;
Tags (1)
RichRuh
Hi Ken,
Your code just makes the edit and adds it to the undo/redo stack.
If you want to save your edits, call
 Project.Current.SaveEditsAsync()
--Rich
RichRuh
Hi Ken,
--Rich
KenBuja
I guess I didn't read far enough through the documentation on this. Using Inspector.ApplyAsync() was much slower than EditOperation.Modify(inspector). I then tested it just using the Modify(Row,String,Object) method and that was much faster than using the Inspector.
GKmieliauskas
"The Inspector.ApplyAsync() method applies and saves the changes in one shot (there is no undo). Whereas EditOperation.Modify(inspector) will apply the changes and add an undo operation to the Pro undo/redo stack on EditOperation.Execute."
https://github.com/Esri/arcgis-pro-sdk/wiki/ProConcepts-Editing
