Edit raster pixel by pixel
2041
06-09-2019 07:04 AM
MaxMax2
I'm trying to edit raster of GDB raster dataset added to map as RasterLayer. I need to set new extent, height, width and cells values. My code is:
var raster = layer.GetRaster();
raster.SetExtent(extent);
raster.SetHeight(rowsCount);
raster.SetWidth(columnsCount);
var pixelBlockHeight = Math.Min(raster.GetHeight(), rowsCount);
var pixelBlockWidth = Math.Min(raster.GetWidth(), columnsCount);
var pixelBlock = raster.CreatePixelBlock(pixelBlockWidth, pixelBlockHeight);
raster.Read(0, 0, pixelBlock);
var sourcePixels = pixelBlock.GetPixelData(0, false);
for (var i = 0; i < pixelBlockHeight; i++)
    for (var j = 0; j < pixelBlockWidth; j++)
        sourcePixels.SetValue(Convert.ToUInt32(1000), j, i);
pixelBlock.SetPixelData(0, sourcePixels);
raster.Write(0, 0, pixelBlock);
raster.Refresh();
But nothing happens. No values are applied. If I get pixel block again, all values are zero. Statistics is empty.
What am I doing wrong?
MaxMax2
Any news on this issue?
Prashant_MukeshMangtani
Max,
Did you check to see if the raster can be edited using raster.CanEdit()? If you know where the raster dataset is you don't need a layer. You can just open the raster dataset, create a full raster and make your edits on it.
https://github.com/esri/arcgis-pro-sdk/wiki/ProConcepts-Raster#opening-raster-datasets
-Prashant
MaxMax2
Hi Prashant,
I need layer since I want to show raster on map. CanEdit returns true. So have RasterLayer in which I need to modify pixels. But my edits are not applied.
Max
MaxMax2
It seems it's impossible to edit pixels of raster layer's raster. Am I right?
