Edit Operation Not Enabling Undo in ArcGIS Pro
240
a month ago
EdwardBlair
All -
I've been trying to find my problem for days and am stuck.   The attached snippet has code that updates feature attributes inside an Edit Operation.   When executed the updates are applied as expected, but the ArcGIS Pro "Undo" does not become enabled.
The crux of the code is below.   The code is attached.
Any suggestions would be GREATLY appreciated.
Thx,
Ed
EditOperation editOperation = new EditOperation() { Name = "Roll Phases" };
editOperation.Callback(context =>
// update stuff
}, listOfFeatureClasses);
try
bool creationResult = await editOperation.ExecuteAsync();
catch (GeodatabaseException geoex)
GKmieliauskas
Take a look to that thread. It is related to dockpane and undo.
EdwardBlair
All -
The code above is being executed from an ArcPro DockPanel.
I realized I have similar code -- that works -- which is being executed from an Pro Window.   So... I took the code from the DockPanel and implemented within a new Pro Window.   And it works!   The data updates are made and the Undo button is enabled.
If anyone has a clue on why this is the case, I would really like to understand what is going on.
Ed
EdwardBlair
I should have further explained that the DockPane implementation follows the MVVM pattern -- as seems to be recommended.   The logic in the Pro Window is defined in the code behind.
Ed
GKmieliauskas
EdwardBlair
Boom!  Just like that..  it works.
Ed
