Hi, I need to develop an add-In to work with utility network. After clicking a button, programmatically disable all subnetwork controllers that have a certain globalId within my device layer in map. For testing purposes, I tried to operate with only one subnetwork controller, in order: create an element, get subnetworkManager from un, disable controller in edit operation, save the project and then do subnetwork update. Sequential operations as in the documentation example
https://pro.arcgis.com/en/pro-app/3.0/sdk/api-reference/topic76342.html
What I notice is that no Dirty Area is created, as if the editing is not being done. I tried as well the DisableController method without editing operation and did not get the desired result.
I am currently using version 3.2.2 of Pro and Geodatabase File.
What am I doing wrong?
CODE SNIPPET:
globalIdSBC.Clear();
globalIdSBC.Add("{77725B0F-B758-4D54-B1D9-4A927CC14F01}");
// globalId string list
string globalIdStringList = string.Join(",", globalIdSBC.Select(id => $"'{id}'"));
QueryFilter filter = new QueryFilter
WhereClause = $"GLOBALID IN ({globalIdStringList})"
// filter.SubFields = "GLOBALID, OBJECTID";
// Count
int rowCount = GetFilteredFeatureCount(deviceLayer, filter);
Debug.WriteLine($"Count: {rowCount}");
var tierD = domainNetwork.GetTier("Distribuzione Primo Salto");
if (tierD == null)
Debug.WriteLine($"Tier: {tierD}");
return;
var subnetworks = utilityNetwork.GetSubnetworkManager().GetSubnetworks(tierD, SubnetworkStates.All);
var subnetwork = subnetworks.FirstOrDefault(x => x.Name == "R_GorlaMaggiore");
using (var cur = deviceLayer.Search(filter))
ArcGIS.Core.Data.UtilityNetwork.Element element = null;
while (cur.MoveNext())
var currentRow = cur.Current;
// Element from row
element = utilityNetwork.CreateElement(currentRow);
// Disable snc
utilityNetwork.GetSubnetworkManager().DisableControllerInEditOperation(element);
// Tried also validate network topology first
UtilityNetworkExtensions.ValidateNetworkTopologyInEditOperation(utilityNetwork);
// Save edits and update subnetwork
await Project.Current.SaveEditsAsync();
subnetwork.Update();
// Save edits
// await Project.Current.SaveEditsAsync();
// I tried update both ways
//foreach (Tier tier in domainNetwork.Tiers)
// utilityNetwork.GetSubnetworkManager().UpdateAllSubnetworks(tier, true);
// var subnetworks = utilityNetwork.GetSubnetworkManager().GetSubnetworks(tier, SubnetworkStates.Dirty);
// foreach (Subnetwork subnetwork in subnetworks)
// subnetwork.Update();
mapView.Redraw(true);
The DisableControllerWithEditOperation should create a dirty area, and calling ValidateNetworkTopologyInEditOperation should clean it so you don't see it.
Hello Aashis,
I thank you for your kind reply. I had not used the ValidateNetworkTopology initially and still the result was the same.
The dirty area is not generated at all because the subnetwork controller remains as such even after disabling, so it is not disabled
@RichRuh sorry for the mention but i think you are the right person to ask 😀
it's possible the method DisableControllerInEditOperation works only with the UN on service and not with UN in the gdb file?
Ciao Daniele,
No, the DisableControllerInEditOperation works equally well with feature services, file geodatabases, and mobile geodatabases.
Are you sure the feature that you are passing to DisableControllerInEditOperation is, in fact, a subnetwork controller?
--Rich
Hi Rich. Thanks for the fast reply.
Yes we are sure that the feature is a subnetwork controller (we pass directly the Global ID and the method)
the strange thing is that the save and discard buttons are enable but no dirty areas are created and no error was return in the whole process.
A screen on what i see in the PRO (Before and after the process)
the snippet of the code.
string globalIdStringList = "'{597AD203-0637-4ABB-B628-6497D3CB74EA}'";
filter.SubFields = "GLOBALID, OBJECTID";using (var cur = deviceLayer.Search(filter))
element = utilityNetwork.CreateElement(cur.Current);
utilityNetwork.GetSubnetworkManager().DisableControllerInEditOperation(element);}
We miss something?
We try with pro 3.1.3 and 3.2.2 and enterprise 11.1
