Converting a georeferencing ArcMap tool to ArcGIS Pro tool
1547
12-16-2022 08:17 AM
Amadeus111
We have an ArcMap tool helping end-users to georeference pdf/tiff maps. The maps come with drawn and numbered grids on them, and the tool uses grid intersections to georeference the map. Also, end-users can create to aid the visibility of a given cell size, row, and column.
I have two questions:
1. I checked the ArcGIS pro georeferencing tool and it is superior to what ArcMap offers. I find functionalities for the old tool already available in ArcGIS Pro except for creating grids. Do you think it is worth converting this old tool ArcGIS Pro tool? I would like to have your opinion on that if you use/know both georeferencing options.
Picture of the old tool. X: Not needed
2. Is there a class/method in the SDK I can use for georeferencing. Maybe something like this :
sourcePoint1 = x, y...
targetPoint1 = x, y...
controlPoints = { sourcePoint1, targetPoint1, ....sourcePointN, targetPointN}
Georeference (controlPoints, CurrentMapProjection, TargetMapProjection)
I found some bits and pieces but nothing that I am looking for.
I would appreciate any help. Thanks in advance!
Wolf
by Esri Regular Contributor
Regarding 2)
you can use GP Tools to perform this workflow (Georeference a raster to a referenced layer—ArcGIS Pro | Documentation)
You can first call on the 'Warp' GP Tool: How Warp works—ArcGIS Pro | Documentation and then use the 'Raster Projection' GP Tool: Project Raster (Data Management)—ArcGIS Pro | Documentation
You can call these GP tools from the SDK.
Amadeus111
@Wolf Thanks for the suggestion, I think I will lose some performance but I will see if I can apply.
