CommitAsync() is not called
1013
11-08-2018 11:17 PM
deleted-user-WOOhbEScR4vX
Hello,
if I override the functions "CommitAsync()" and "CancelAsync()" from the class "ArcGIS.Desktop.Framework.Contracts.Page" the functions are not called when I press OK or Cancel in the GUI. Can anybody confirm this bug or am I doing something wrong?
public class ProApplicationSettingsViewModel : Page
          /// <summary>
          /// Invoked when the OK or apply button on the property sheet has been clicked.
          /// </summary>
          /// <returns>A task that represents the work queued to execute in the ThreadPool.</returns>
          /// <remarks>This function is only called if the page has set its IsModified flag to true.</remarks>
          protected override Task CommitAsync()
               MessageBox.Show("OK clicked.");
               return Task.FromResult(0);
          protected override Task ResetAsync()
               return Task.FromResult(true);
          protected override Task CancelAsync()
          /// <summary>
          /// Called when the page loads because to has become visible.
          /// </summary>
          protected override Task InitializeAsync()
          /// <summary>
          /// Called when the page is destroyed.
          /// </summary>
          protected override void Uninitialize()
InitializeAsync() and Uninitialize() are working fine.
Thank you for your help.
Best regards.
CharlesMacleod
Flag your page as "dirty" - this.IsModified = true - this tells the property sheet that you have changes to commit. This guide might help - it does a step-by-step implementation: https://github.com/esri/arcgis-pro-sdk/wiki/ProGuide-Custom-settings
CharlesMacleod
