Buffer Shape
4755
08-20-2015 05:39 AM
mikeharol1
I would like to buffer a  polygon with the arcgispro sdk.
Here is basic concept in arcobjects
var pTopo = myFeature.Shape as ITopologicalOperator;
IPolygon pOutPoly = (IPolygon)pTopo.Buffer(dblBufDis);
what is most efficient way to do this with arcgispro sdk?
Thanks
Mike
ThomasEmge
The buffer snippet boils down to something like this:
using ArcGIS.Core.Geometry;
QueuedTask.Run(() => {
   var bufferGeometry = GeometryEngine.Buffer(feature.GetShape(), dblBufDis);
ThomasEmge
mikeharol1
thanks.  My snippets do not appear to be available in the IDE.  should they be available after installing sdk?
ThomasEmge
We have 'ProSnippets' as part of the wiki at
https://github.com/esri/arcgis-pro-sdk/wiki next to the concepts.
You can find the geometry snippets at
https://github.com/esri/arcgis-pro-sdk/wiki/ProSnippets-Geometry
mikeharol1
Wow, that's a big help, guess i should have known about that resource.
