ArcGIS Pro SDK for .NET version 3.3
5115
12-11-2024 02:20 PM
RichardMoussopo
Hello there, I am trying to build an extension using ArcGIS Pro SDK for .NET. I have ArcGIS Pro 3.3 and don't want to upgrade. In visual Studio when installing the extension, it always installs the latest version (3.4). Is there a way to install the SDK version 3.3?
I also tried installing these through the commend line but it says packages not found.
Install-Package Esri.ArcGISPro.SDK -Version 3.3.0.52636
Install-Package Esri.ArcGISPro.SDK.Utilities -Version 3.3.0.52636
tempStephenRhea_NV5
Before installing the SDK, be sure to disable automatic extension updates in Visual Studio. Otherwise VS will push you right back to 3.4.
After that, head to the Github releases page (https://github.com/Esri/arcgis-pro-sdk/releases). If you scroll to the bottom of the 3.3 section and expand the Assets, you'll find the .vsix files.
tempStephenRhea_NV5
RichardMoussopo
That did the trick, thank you
tempStephenRhea_NV5
Awesome! You're welcome.
