ArcGIS Pro SDK C#: How to Create Layer and Add it to Active Map
3435
01-20-2022 08:15 AM
JadedEarth
I'm trying to add a feature class to my Active Map from an SDE geodatabase connection.  My code is as follows inside a button-click event:
string url = @"E:\WorkingFolder\SWATAddIn\GIS_TMP_Connection.sde\MG.dbo.APEX_SWAT_COMP_HUC8";
Uri uri = new Uri(url);
await QueuedTask.Run(() => LayerFactory.Instance.CreateLayer(uri, MapView.Active.Map));
However, it doesn't load and the error says it's unable to add data (doesn't explain why).  If I remove the "MG.dbo." notation before the feature class name, it flags, "Data is not suppported."
What am I doing wrong?
Appreciate any help.
JadedEarth
Hi y'all,
Found out the problem:  The spatial table I was trying to add didn't have an OBJECTID.  I modified the table to add an IDENTITY(1, 1) integer.
It's now loading.  Easy to forget such things.
JadedEarth
Hi y'all,
FredericPoliart_EsriAU
Is drive E: a shared drive?
Try using a URL to a layer (ex https://domain.com/ArcGIS/rest/your map server/3/ ), To check if that gets accepted, first.
