ArcGIS Pro per-user installation ignores ConfigurationName and Configuration Folders Registry Keys
362
06-05-2026 04:37 AM
marco_vertigis
While testing ArcGIS Pro with a per-user installation, I noticed behavior that appears different from what is documented regarding automatic configuration discovery.
According to the SDK documentation, ArcGIS Pro can automatically locate a .proConfigX configuration using the following registry keys:
  • HKLM\SOFTWARE\ESRI\ArcGISPro\Settings\Configuration Folders
  • HKLM\SOFTWARE\ESRI\ArcGISPro\Settings\ConfigurationName
Documentation:
https://doc.esri.com/en/arcgis-pro/latest/sdk/api-reference/conceptdocs/docs/ArcGIS-Pro-Registry-Key...
In my testing, ArcGIS Pro successfully recognizes these values when they are defined under HKLM. However, equivalent values placed under HKCU do not appear to be considered during startup.
This raises a few questions:
  1. Is support for HKCU registry keys intentionally not implemented for configuration discovery?
  2. Is there an alternative mechanism recommended for per-user deployments that need to automatically load a custom .proConfigX?
  3. Are there any plans to support configuration discovery from the current-user registry hive in future releases?
At the moment, the only reliable approach I have found is to:
  • Deploy the .proConfigX file into the default user configuration location.
  • Launch ArcGIS Pro using a shortcut that explicitly specifies the /config:<ConfigurationName> command-line parameter.
Can anyone from Esri confirm whether this is the expected behavior for per-user installations, or if there is another supported approach?
Thank you.
