I added a ProWindow in my Add-In. Then I added 2 rows. On the Grid.Row="0", I added an image tag:
<Image Margin="197,21,0,0" HorizontalAlignment="Left" VerticalAlignment="Top" Height="60" Width="60" Source="swat256.png" Visibility="Visible" Grid.Row="0"/>
But when I ran my add-in the ProWindow displays WITHOUT showing the image.
What am I doing wrong? XAML code:
<controls:ProWindow x:Class="SWAT_.SwatWindow"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:controls="clr-namespace:ArcGIS.Desktop.Framework.Controls;assembly=ArcGIS.Desktop.Framework"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:extensions="clr-namespace:ArcGIS.Desktop.Extensions;assembly=ArcGIS.Desktop.Extensions"
mc:Ignorable="d"
Title="SWAT+ SQL Server Tools v.1.0.0" Height="400" Width="500"
WindowStartupLocation="CenterOwner" FontFamily="Segoe UI"
<controls:ProWindow.Resources>
<ResourceDictionary>
<ResourceDictionary.MergedDictionaries>
<!--<extensions:DesignOnlyResourceDictionary Source="pack://application:,,,/ArcGIS.Desktop.Framework;component\Themes\Default.xaml"/>-->
</ResourceDictionary.MergedDictionaries>
</ResourceDictionary>
</controls:ProWindow.Resources>
<Grid>
<Grid.RowDefinitions>
<RowDefinition Height="96*"/>
<RowDefinition Height="275*"/>
</Grid.RowDefinitions>
<Button x:Name="BtnSqlConnect" Content="Create SQL Server Database Connection" HorizontalAlignment="Center" Margin="130,51,134.333,0" VerticalAlignment="Top" Height="21" Width="229" Click="BtnSqlConnect_Click" Grid.Row="1"/>
<Button x:Name="BtnReset" Content="Initialize Tables" HorizontalAlignment="Center" Margin="128,96,134.333,0" VerticalAlignment="Top" Height="21" Width="231" Click="BtnDropTables_Click" Grid.Row="1"/>
<Button x:Name="BtnClose" Content="Close" HorizontalAlignment="Left" Margin="206,223,0,0" VerticalAlignment="Top" Height="23" Width="75" Click="BtnClose_Click" Grid.Row="1"/>
</Grid>
</controls:ProWindow>
Appreciate any help.
1. Check image properties in Visual Studio. "Build Action" must be set to "Resource".
2. Check image location in project. From your code it must be in the root of project. Maybe it in the "Images" folder.
3. Sometimes helps another way of image location defining:
<Image Source="/your_addin_name;component/your_image_relative_path" />
