ArcGIS Pro Add-in: How to use Geoprocessing tools
4046
01-13-2022 06:30 AM
JadedEarth
I'm creating an Add-in Application for ArcGIS Pro v2.9 using Visual Studio 2019 in C#.
How do I access the geoprocessing assemblies so I can execute them in my codes?  I have the following code but I'm getting an error:  "Unable to load DLL ArcGISVersion.dll.  The specified module could not be found."
Here's my code snippet:
using ESRI.ArcGIS.Geoprocessor;
using ESRI.ArcGIS.DataManagementTools;
private void ConnectToSQLServerDb()
            //Declares variables here...
            //Initialize a geoprocessing object
            Geoprocessor GP = new Geoprocessor();
            CreateDatabaseConnection dbCon = new CreateDatabaseConnection();
            try
                //Specify parameters
                dbCon.out_folder_path = outFolder;
                dbCon.out_name = outName;
                dbCon.database_platform = dbPlatform;
                dbCon.instance = sqlInstance;
                dbCon.database = dbName;
                dbCon.account_authentication = "OPERATING_SYSTEM_AUTH";
                //Execute tool
                GP.OverwriteOutput = true;
                GP.Execute(dbCon, null);
            catch (Exception ex)
                ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("Failed to reset table: " + ex.Message, "Error Message", MessageBoxButton.OK, MessageBoxImage.Error);
            finally
                GP = null;
                dbCon = null;
KenBuja
MVP Esteemed Contributor
This looks like code from ArcObjects to run Geoprocessing tools. It's much different in ArcGIS Pro, using different assemblies and supplying the parameters using a list of arguments rather than properties. Take a look at the documentation on how to run Geoprocessing tools.
Here's an example I use that runs the "Create Feature Class" tool.
using ArcGIS.Desktop.Core.Geoprocessing;
using ArcGIS.Core.Geometry;
using System.Collections.Generic;
using System.Threading.Tasks;
   public static async Task<IGPResult> CreateLayer(string path, string featureclassName, string featureclassType, int SR_wkid)
      List<object> arguments = new List<object>
        // store the results in the default geodatabase
        //CoreModule.CurrentProject.DefaultGeodatabasePath,
        path,
        // name of the feature class
        featureclassName,
        // type of geometry
        featureclassType,
        // no template
        // no m values
        "DISABLED",
        // no z values
        "DISABLED"
      await QueuedTask.Run(() =>
        // spatial reference
        arguments.Add(SpatialReferenceBuilder.CreateSpatialReference(SR_wkid));
      IGPResult result = await Geoprocessing.ExecuteToolAsync("CreateFeatureclass_management", Geoprocessing.MakeValueArray(arguments.ToArray()), null, null, null, GPExecuteToolFlags.None);
      return result;
KenBuja
        path,
        featureclassName,
        // type of geometry
        featureclassType,
        // no template
        // no m values
        "DISABLED",
        // no z values
        "DISABLED"
      return result;
JadedEarth
Got it.  I changed the codes to:
//Namespaces used
using ArcGIS.Desktop.Framework.Dialogs;
var args = Geoprocessing.MakeValueArray(outFolder, outName, server, sqlInstance, "OPERATING_SYSTEM_AUTH", dbName, "Transactional");
var gp_result = Geoprocessing.ExecuteToolAsync("CreateDatabaseConnection_management", Geoprocessing.MakeValueArray(args.ToArray()));
ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("Finished creating database connection: ", "Result", MessageBoxButton.OK, MessageBoxImage.Information);
JadedEarth
How do I make a call to CreateLayer from Button_Click event?
Thanks
KenBuja
This is how I call it and use the result
var result = await CreateLayer(System.IO.Path.GetDirectoryName(output), System.IO.Path.GetFileName(output), "POINT", SR.Wkid);
using (var outputFC = GDBItemHelper.GetDatasetFromPath(result.ReturnValue) as FeatureClass) {}
Esri Support supplied the code for the GDBItemHelper class since this wasn't readily apparent in the Pro SDK documentation
using ArcGIS.Core.Data;
using ArcGIS.Desktop.Core;
using ArcGIS.Desktop.Framework.Threading.Tasks;
using System;
using System.Linq;
using System.Text;
namespace xxxx //use your own namespace
  internal static class GDBItemHelper
    public const int lengthOfFileExtension = 4;
    // Keywords
    public const string FeatureClassKeyword = "Feature Class";
    public const string FeatureDatasetKeyword = "Feature Dataset";
    public const string TableKeyword = "Table";
    public const string RelationshipClassKeyword = "Relationship Class";
    //async flavors
    public static Task<Dataset> GetDatasetFromItemAsync(Item item)
      return QueuedTask.Run(() => GetDatasetFromItem(item));
    public static Task<Dataset> GetDatasetFromPathAsync(string path)
      return QueuedTask.Run(() => GetDatasetFromPath(path));
    //Sync flavors - use the QueuedTask
    public static Dataset GetDatasetFromItem(Item item)
      if (!QueuedTask.OnWorker)
        throw new ArcGIS.Core.CalledOnWrongThreadException();
      if (item.TypeID.StartsWith("fgdb_") || item.TypeID.EndsWith("_fgdb"))
        return OpenDatasetForExtension(".gdb", item);
      if (item.TypeID.StartsWith("egdb_") || item.TypeID.EndsWith("_egdb"))
        return OpenDatasetForExtension(".sde", item);
      if (item.TypeID.StartsWith("shapefile_"))
        return OpenDatasetForExtension(".shp", item);
      return null;
    public static Dataset GetDatasetFromPath(string path)
      //check the path
      int indexOfgdb = path.LastIndexOf(".gdb", StringComparison.InvariantCultureIgnoreCase);
      if (indexOfgdb == -1)
        indexOfgdb = path.LastIndexOf(".sde", StringComparison.InvariantCultureIgnoreCase);
        indexOfgdb = path.LastIndexOf(".shp", StringComparison.InvariantCultureIgnoreCase);
        return null;
      //make the item
      var item = ItemFactory.Instance.Create(path);
      //retrieve the dataset
      return GetDatasetFromItem(item);
    private static Dataset OpenDatasetForExtension(string extension, Item item)
      int indexOfgdb = item.Path.LastIndexOf(extension, StringComparison.InvariantCultureIgnoreCase);
        return null;
      string gdbPath = item.Path.Substring(0, indexOfgdb + lengthOfFileExtension);
      if (extension == ".sde")
        using (ArcGIS.Core.Data.Geodatabase geodatabase = new ArcGIS.Core.Data.Geodatabase(new DatabaseConnectionFile(new Uri(gdbPath))))
          if (item.TypeKeywords.Contains(FeatureClassKeyword))
            return geodatabase.OpenDataset<FeatureClass>(item.Name);
          if (item.TypeKeywords.Contains(FeatureDatasetKeyword))
            return geodatabase.OpenDataset<FeatureDataset>(item.Name);
          if (item.TypeKeywords.Contains(TableKeyword))
            return geodatabase.OpenDataset<Table>(item.Name);
          if (item.TypeKeywords.Contains(RelationshipClassKeyword))
            return geodatabase.OpenDataset<RelationshipClass>(item.Name);
      else if (extension == ".gdb")
        using (ArcGIS.Core.Data.Geodatabase geodatabase = new ArcGIS.Core.Data.Geodatabase(new FileGeodatabaseConnectionPath(new Uri(gdbPath))))
      else if (extension == ".shp")
        var shapePath = System.IO.Path.GetDirectoryName(gdbPath);
        using (ArcGIS.Core.Data.FileSystemDatastore shape = new FileSystemDatastore(new FileSystemConnectionPath(new Uri(shapePath), FileSystemDatastoreType.Shapefile)))
          return shape.OpenDataset<FeatureClass>(item.Name);
      return null;
