ArcGIS Pro 2.4 add in that would execute after a project is loaded
3169
6
08-12-2019 06:47 AM
FrankMartin1
I have an ArcGIS Pro 2.4 add in that I would like to have execute after a project is loaded, but does not require the user to click a button or select a tool.  Essentially, it would act like a onload function.   Is there any way to accomplish this with an add in?
Thanks for your help,
Frank
FrankMartin1
Thanks to everyone for their suggestions.  I used Than's suggestion to subscribe to the ActiveMapViewChangedEvent in the module (se below), and it works.  Now, when a project loads the add in code is executed immediately without having to activate it through a button.  I used Uma's suggestions to "hide" the button by setting the the loadOnClick attribute to false in the button definition.
Again, thanks to everyone for their help!
Regards,
Frank
        protected override bool Initialize()
            ArcGIS.Desktop.Mapping.Events.ActiveMapViewChangedEvent.Subscribe(MapViewActivateEvent);
            return true;
        private void MapViewActivateEvent(ActiveMapViewChangedEventArgs obj)
            try
               var layerEventListeners = new List<string>();
               var featureLayers = mapView.Map.Layers.OfType<FeatureLayer>();
UmaHarano
Hi Frank,
In your add-in's config.daml, set the  "autoLoad" attribute to true and the button element's loadOnClick attribute to false to accomplish this.
<modules>
<insertModule id="QueryBuilderControl_Module" className="Module1" autoLoad="true" caption="Module1">
 <controls>
  <!-- add your controls here -->
  <button id="QueryBuilderControl_DefinitionQueryDockPane_ShowButton" loadOnClick="false" caption="Show DefinitionQueryDockPane" ...>
          <tooltip heading="Show Dockpane">Show Dockpane<disabledText /></tooltip>
        </button>
 </controls>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Thanks
Uma
FrankMartin1
Uma,
Thanks.  I've changed both the autoLoad and loadOnClick as you suggested, however, the button code does not execute until the button has been click.
<modules>
 <insertModule id="EditRBIDGeneratorPro_Module" className="Module1" autoLoad="true" caption="Module1">
<button id="EditRBIDGeneratorPro_Button1" caption="RBID Activate" className="Button1" loadOnClick="false" ...>
 <tooltip heading="RBID Activate Tooltip">Click to ensure the automatic addition of a RBID during edit sessions<disabledText /></tooltip>
The code I'm trying to execute is within the the OnClick function.  Is that the issue?
namespace EditRBIDGeneratorPro
 internal class Button1 : Button
   private Incrementor uid;
   protected override async void OnClick()
     try
         var mapView = MapView.Active;
         if (mapView == null)
             var startString = "No map view";
             MessageBox.Show(startString);
         var featureLayers = mapView.Map.Layers.OfType<FeatureLayer>();‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
     catch (Exception ex)
         var ErrorString = ex.Message;
         MessageBox.Show("An error occurred while updating attribute column data " + ErrorString);
Thanks again,
Frank
ChristopherMoore
You'll probably want to subscribe to the project opened event in your EditRBIDGeneratorPro_Module.Initialize method, for example:
internal class EditRBIDGeneratorPro_Module : Module
    ArcGIS.Desktop.Core.Events.ProjectOpenedEvent.Subscribe(async (args) => {
       // Call Desired Method
- Chris
UmaHarano
Hi Frank,
The loadOnClick attribute only determines when the button should be created by the framework.
Thanks
Uma
by Anonymous User
Not applicable
Hi Frank,
Based on your button click event code, it seems you are trying to perform something when the mapview is active.
If so,
Use this,
In module class, add these
ArcGIS.Desktop.Mapping.Events.ActiveMapViewChangedEvent.Subscribe(this.MapViewActivateEvent);
return true;
try
ProDialog.MessageBox.Show(startString);
ProDialog.MessageBox.Show("An error occurred while updating attribute column data " + ErrorString);
FrankMartin1
Regards,
Frank
            return true;
            try
