Annotation not displayed correctly if map has an angle and annotation's location is a MapPoint
621
09-30-2024 05:18 AM
MartinTyberg
Hi - I encountered what appears to be a bug in Pro. If I create an annotation with an angle such that after the map is rotated by the map's defined map angle, the annotation will be horizontal and I specify the annotation's location with a MapPoint, the annotation will not appear horizontal on the map. However, if I change the MapPoint to a Polyline, then the annotation appears horizontal. Has anyone else encountered this? Btw, when the map has no map angle, then all annotations defined with a MapPoint location appear correctly - either horizontal if the textsymbol's angle is 0 or rotated at the textsymbol's angle.
Martin
