Please add QueryPointsAndDistances method to IGeometryEngine Interface
2614
6
04-20-2024 02:06 PM
Status: Implemented
MRJ1
In the ArcObjects SDK there is a method called QueryPointsAndDistances, which is a member of the ICurve3 Interface. Can you please add support for this in the ArcGIS Pro SDK as part of the IGeometryEngine Interface under the ArcGIS.Core.Geometry namespace? This functionality would be really useful for my linear referencing work. Please note: this method is not to be confused with the QueryPointAndDistance method, which is already available in the Pro SDK but only returns a single map point and does not provide an enumerator returned from QueryPointsAndDistances available in ArcObjects. Thank you!
6 Comments
AnnetteLocke
We will add it in the next release. Thank you for the suggestion.
Annette
MRJ1
Hi. Still looking for this specific functionality to be implemented in the ArcGIS Pro SDK. The method provides an enumerator over all the closest points on a geometry given an input point:
https://desktop.arcgis.com/en/arcobjects/latest/net/webframe.htm#ICurve3_QueryPointsAndDistances.htm
Thank you!
AnnetteLocke
This functionality has been added to the next release which is 3.5.
VedantBajaj
Hi, This has been implemented as QueryPoints.
AnnetteLocke
There are two new methods.
IReadOnlyList<MapPoint> QueryPoints(Segment segment, SegmentExtensionType extensionType, IEnumerable<double> distancesAlongCurve, AsRatioOrLength asRatioOrLength)
IReadOnlyList<MapPoint> QueryPoints(Multipart multipart, SegmentExtensionType extensionType, IEnumerable<double> distancesAlongCurve, AsRatioOrLength asRatioOrLength)
AnnetteLocke
Correction: This was added in 3.4.
