Writing if/else statement in field calculator for calculating values
3439
06-11-2018 03:43 PM
Brian_McLeer
MVP Regular Contributor
I have referenced this article Writing conditional (if/then) statements into Field Calculator of ArcGIS for Desktop using Python pa...
I am trying to update values in a field using 'elif' statements in Field Calculator with the Python radio button selected.
The set is as:
Code Block:
def Reclass(Density_18):
                if (Density_18 <= .8493):
                                return 1
                elif (Density_18 >.8493 and Density_18 <=1.761):
                                return 2
                elif (Density_18 >1.761 and Density_18 <=2.345):
                                return 3
                elif (Density_18 >2.345 and Density_18 <=3.399):
                                return 4
                elif (Density_18 >3.399):
                                return 5
Expression:
Reclass( !Index_18!)
When this expression is performed, it calculates all the values as '1', then the next time it is run all values are '2', so on until it maxes out and repeats at '5' in the Index_18 field.
DanPatterson_Retired
Indentation is a bit off, but I tested it after reformatting using individual values and it is fine.
I suspect that the !Index1! field is the field you are trying to put the values IN and not the field that contains the Density values... check that
Python parser, as before
        return 1
        return 2
        return 3
        return 4
        return 5
Reclass(Density_18)
Density_18 = .1
Reclass(Density_18)
        return 1
        return 2
        return 3
        return 4
        return 5
Reclass(Density_18)
Density_18 = .1
Reclass(Density_18)
