why no scrollbar in empty table view
1355
01-19-2017 11:55 AM
AlexanderGray
Honored Contributor
I have a feature class with no features in a map.  It has many fields.  If I open the table view, I can't see all the fields because they don't all fit in the dockable window.  I can't scroll right the see the fields because there is no horizontal scrollbar.  The horizontal scrollbar only shows up when there are rows in the table.
DanPatterson_Retired
I have seen similar issues in the inability to scroll through fields in a table... my solution, just open another table, then switch back to the empty table... is the scroll bar active now?  At least in arcmap, the table views sometimes need a kick by switcching between open tables to get 'stuff' to work.  quirky? yes...  but has worked for me
