Why is layout rendering so slow?
359
4 weeks ago
AlfredBaldenweck
MVP Frequent Contributor
Can't remember if I've asked this before, but I'm working on a project where it's really starting to bite me.
Why is the layout sooooo slow to render?
In my case today, I have a (n admittedly very large-- 16x40") canvas and a map frame of the same size. I'm drawing at a pretty detailed scale for something at that size -- 1:300K. No marginalia yet, and the map itself is pretty complicated. So, I get it, I'm asking Pro to do a lot of detail.
That being said, it's taking 10 minutes to draw or redraw with every. single. change. This is very painful.
I get that Pro is going to struggle the more you throw at it, etc. However, isn't rendering a map frame in the layout basically the same as rendering a Map View at a certain reference scale? My map view is positively zippy by comparison-- I can refresh the entire intended extent with a reference scale set and it takes like 20-30 seconds, instead of several minutes.
So, my question is: What is going on in the Layout view that makes it soooooooooooooooooo sloowwwwwwwwww in comparison to the map view?
This is not the first time I've run into this, nor will it be the last. Layout has serious performance issues once you get bigger than like, 8.5x11" canvas, but even at that size there's a notice difference in performance between it and the map view. Why, and can it be fixed?
JonM32
@AlfredBaldenweck
This is pretty common in ArcGIS Pro. Most maps I make I do my work in the map itself, and try to stay out of the layout since performance degrades quickly. Loading times get bad.
I found if I do work in the layout and want to adjust the map I try to zoom in close and work in small areas. But yeah, it's not the best especially if you have a lot of labels and other data going on.
You can always pause labeling, or use draft quality to help speed things up. Or turn off anything you don't need to see at the moment.
Cheers,
Jon
If this response helps or is the solution to your post, please consider marking it as a solution
CraigWilliams
One thing to note is that on layout draw operations like labeling are using the full map frame extent even if you're zoomed in. This allows us to zoom in on the page and see a magnified view of the final product. That's very different than map draw where just the current visible extent is used.
Your differences seem very large though and it's hard to speculate more without seeing the specific example. Have you logged a support incident for this? What version of ArcGIS Pro are you using.
AlfredBaldenweck
Fair enough, but again, I don't see how that's meaningfully different from viewing the entire intended extent in Data view with a reference scale applied. That would also draw the entire extent at a specified scale, right?
I ended up getting some improvement by exporting everything to a vector tile package and using that instead. It draws more easily, but I had to know which scale I wanted from the get-go, and any adjustment means I have to do it all over again. Also, vector tile packages don't respect my label weights, so...
I have not bothered to put in a support ticket, although I did mention it in a Voice of the Customer interview a year or two back, and I'm hoping it was one of the reasons Pseudo-draft mode was implemented. In other words, I've been having a problem with this since pro 2.9, at least, and I also mention it on the semi-regular surveys that get sent out. (My general phrasing is something like "please test on a canvas larger than 8.5x11"). To answer your question, am on 3.5 now.
To be fair, I'm also having incredible performance issues with just plain text elements on the canvas for a different layout (11x17). There's a map frame, but it's completely turned off, and then I have 4 text elements. Super laggy trying to add and edit them this morning. My virtual desktop has about 28GB of RAM, which should be plenty.
I mean, for a really fun thing, make a big layout, add a map frame with a map containing a few layers, add a legend, turn off the map frame, then try editing the legend. Takes forever, and gets worse the larger you make the legend. Honestly, I've had similar problems on 8.5x11 canvases, so it's definitely exacerbated by canvas size but not caused by it.
So I guess there are two things going on: 1) Performance is awful even for marginalia and 2) rendering map frames is bad.
Robert_LeClair
Esri Esteemed Contributor
Although not specific to the layout issue, in ArcGIS Pro 3.7 there's a new Analyze Map Pane you can use to troubleshoot slow layers/issues - you can read more about it here - Evaluating Your Map’s Drawing Performance: The Analyze Map Pane
DuncanHornby
MVP Notable Contributor
May not be relevant to your situation but something I've tripped up on that hammers performance is to have a layer displaying unique values, but many thousands of them.
