Why does ArcGIS Pro crash when setting domain?
4621
10
02-13-2019 10:34 AM
MichaelFazio2
I am trying to set domains for a GeoDatabase that will be used in an ArcCollector app. Everytime I try to set a domain to type "Double" in which the user must submit a value within a given Range, the program crashes. E.g. I have a temperature field inwhich the user needs to be able enter the temperature with up to one decimal point. Everytime I try to enter the lower value limiter, the program crashes. I have also tried this with type "Float", but still no success. Seems ArcPro does not like using Ranges for decimal value?
Is anybody else having this problem?
Thanks in advance!
ThomasColson
I was able to force a crash by having two feature classes from two SDE's open in design view. No crash dump this time (I did send one earlier today from "Create ENT GDB"), only this.
