why do zip codes show in wrong state?
2023
5
12-11-2017 02:56 PM
MarieMaresh
I'm having a problem when creating layers with zip codes.  Some of my zip codes are showing up in the wrong states.  I have made sure to format my zips as text.  I'm not sure what to do to correct this.  It is throwing my data off.
DanPatterson_Retired
some examples codes? and where should they be? and where are they showing up?
MarieMaresh
Hi Dan,
The should all be in Texas and originally I thought they may be PO Box zips, but they are showing up all over the place with demographic info attached. Below are a few examples. Thank you for your help.
Zip
Should be:
Showing up:
77993
Goliad County TX
Indiana
78342
Jim Wells County TX
Tennessee
78144
Karnes County TX
North Carolina
78333
Jim Wells County TX
Pennsylvania
JoshuaBixby
How are you creating your "layers with zip codes," i.e., what steps are you taking to generate the layer.
MarieMaresh
Hi Joshua, I created a table with the zip codes, formatted them to text, and added the data.
JoshuaBixby
There has to be more to it than that because loading a TXT or CSV with zip codes in it simply creates a table in Pro.  I assume you geocoded those zip codes in the table after adding them.  What tools and arguments did you use to geocode?
I used the Geocode Address tool in Pro to geocode a handful of zip codes, including a couple you listed.  The locations all showed up in the right place.
