Why do I get a bad value error when I ran Calculate Field
1262
05-30-2025 09:42 AM
DEAF_PROBERT_68
Honored Contributor
As I type the word Replace in the field using Calculate field to replace the I- to 255, however I get this error message. Has anyone went through this error and got it to fix ?
I looked at the Text Functions on ArcGIS Arcade in the ESRI Developer exactly but do not know why... Maybe some of you can help me out...
JoshuaBixby
MVP Esteemed Contributor
You have $feature.SignSymbols wrapped in quotes, which makes it a string and not a reference to the feature.
DEAF_PROBERT_68
Honored Contributor
So should I say or type it in as   Replace($feature.SignSymbols, "I-", "22")  ?
Joshua-Young
MVP Regular Contributor
Won't the Replace function create a new value of "225225"? Is the goal to remove the "I-" and just have a value of "225"? Could you just select all the features with a sign symbol of "I-225" and do a simple calculation of "225" as the new value?
"Not all those who wander are lost" ~ Tolkien
DEAF_PROBERT_68
Honored Contributor
Actually the workaround I did was to use the select by attributes and then open the attributes in the selection menu and in the Attribute dialog box .  Click at the layer name and then go down to the field and type that number....
