Why do disabled WMS service layers still show up in the legend when map is exported?
2130
05-20-2020 12:33 PM
MathesSilas
I'm using some WMS service layers in ArcGIS Pro version 2.5.1.  I can turn off the WMS layers in the table of contents and the legend, and they appear to be correctly removed from the legend in the layout.  However, when I export my map to a PDF the WMS service layers appear in the legend.
Is there a workaround for this, other than converting the legend to graphics?
KoryKramer
Esri Community Moderator
This would be best in the ArcGIS Pro‌ space.
I realize this is frustrating, but it sounds like you're running into [BUG-000130800: Printed layouts generated in ArcGIS Pro 2.5.1 include their Web Map Services (WMS) in legends even if the legend item is deactivated in the Contents pane.]
It's new enough that it doesn't appear to be published yet to support.esri.com, so if you need to be attached, please contact Technical Support.
The listed workaround is: "Remove the legend entry for the WMS by deactivating the New layer option under Synchronize with map. Please note: it remains unclear whether this has broader implications."
Hope this helps!
KoryKramer
Hope this helps!
MathesSilas
Thanks for the quick answer, Kory.  I must have missed the ArcGIS Pro space--I'll try to move it there if possible.
