Which License required
1527
03-08-2017 11:34 PM
KamalMittal
I want to create a map having functionality of offline routing and searching in ArcPro what should i need ?
JayantaPoddar
MVP Alum
Are you looking for Navigation Maps (Navigator)?
FAQs - Navigator
Which licenses do I need to work with navigation maps?
This depends on whether you want to use an Esri-provided navigation map as it is, create your own navigation map with entirely your own data, or modify an Esri-provided navigation map. You may also need additional licenses depending on how much you want to modify an Esri navigation map. The following are the answers to this question based on use case:
You might like to contact your local Esri distributor for further information.
Think Location
