When entering data in a field sometimes the first character ends up as the last
4379
9
03-26-2020 12:19 PM
JeffLegato1
Unfortunately, this appears to be an intermittent bug as I can't seem to recreate the conditions for when it happens.  Occasionally, when entering data, I'll click in a field in the table view and enter data like '1234' and sometimes I'll look back and the data was recorded as '2341'.  It seems that sometimes after I enter the first character the following characters are recorded as being to the left of the first character.  Anyone else experiencing this?  I couldn't find anything on the forums related to it.
DanPatterson_Retired
Jeff Legato‌  !!!
Boredom lead me to
BUG-000125106: When quickly editing a table using Enter, the cursor..
First hit on a search using " table enter front "
I am sure you would have nailed it eventually
do you remember moving the mouse or clicking in the cell twice?  I saw it once entering text and I had done the first
JeffLegato1
I got the behavior to happen in an empty cell after I tabbed into it.  It has also happened when I clicked on the cell once.  It hasn't happened when I have clicked on the cell twice to get the cursor within the cell.
sadly, intermittent probably means not reproducible ... if you can do so, then it might be an issue for Tech Support
JeffLegato1
Right.  I wanted to get this issue up on the board so ESRI can at least know it's happening as I know they take data accuracy very seriously and would stomp this bug if they could get their hands around it.
KoryKramer
Esri Esteemed Contributor
Jeff, if you hit the Subscribe button it will increment the count of affected customers, and also set you up for status notifications:
JeffLegato1
Subscribed.  Thank you.
Jeff Legato‌  !!!
Boredom lead me to
JeffLegato1
You found it!  I'm so glad i'm not losing my mind over here!
Good to know it's a legit bug that ESRI is aware of. Thank you for finding this Dan Patterson‌!
Jeff Legato‌can you mark the thread answered so it will bubble up to the top next time someone searches for this.
