Warning 000728
1466
09-17-2024 07:36 AM
VanessaCcantoAsto
When I create an feature class I always get the Warning 000728: The object Id. field does not exist in the table. I don't know what that means or if it affects my feature class at all. But how do I fix it?
Robert_LeClair
Esri Esteemed Contributor
How are you creating the feature class in ArcGIS Pro?  In the Catalog Pane and a right-click on the geodatabase->New->Feature Class or using the Create Feature Class GP tool?
VanessaCcantoAsto
I do the first thing, the Catalog panel.
Robert_LeClair
Would you able to test the workflow using the Create Feature Class geoprocessing tool to see if it "errors" out with the same error message?
