Varying Rotation by attribute picks up Primary Symbology Domain
901
5
03-17-2023 01:21 PM
Labels (2)
piratecheese
I have primary symbology set to field "Type" and want to use field "Angle" to rotate the symbols. For some reason, it's picking up the "HeadType" domain. It doesn't have this problem when I set the rotation field to "none". It doesn't happen if I set the "Primnary Symbology" to "Single Symbol" (which was my instrument in band)
This stays an issue when the rotation field is floating, short and double. Rotation must be a numeric field
I am aware that "circle" is misspelled .
LukeAllen2
Hi @piratecheese (cool name) did you ever find a resolution to your issue? I believe I'm experiencing a similar problem!
piratecheese
A: I think I used a python arcade script to handle it
B: unfortunately I don't have that script on hand because my org has gone to qgis
LukeAllen2
wow 4 minute response time 🙂 - no worries. Just confused as to why it would be picking up the symbology/domain field when there was no domain applied to the rotation field. Doesn't make much sense; guessing perhaps it's a bug - I can still enter numeric values into the field to get the rotation I need.
piratecheese
between 4-4:30 eastern I'm making calls out to nail down a plan for tomorrow and shooting emails.
If you had sent the question at 8 am I'd have gotten back to you around 1
And the username is a reference to a cheat code in age of empires 2
LukeAllen2
Great game - sunk many hours into it on MSN Zone *reminisces*
