Validate Topology Fixes - Suggested Functions Remove Entire Features
3312
01-29-2020 08:17 AM
jblng
I am validating geodatabase topology rules "May not Overlap (Area)" and "May not have Gaps (Area)" in a single feature class of administrative boundaries. When I run validate topology for these errors, select an error, and go to Fix polygon overlap or gap slivers, the suggested functions such as Merge or Remove Overlap end up deleting entire features of my layer. Rather than delete an entire feature where the overlap or gap occurs, I want to merely merge or remove those slivers or snap the boundaries to one another.
Please see attached an example of an overlap error, and the results when I run either a Merge or a Remove Overlap on the error.
How can I fix overlap or gap validation errors by just fixing the errors themselves and preserving the rest of features? I would appreciate any tips on what I'm missing here.
Thank you!
Scott_Harris
Hi Jo,
For me, when I select a Must Not Overlap error in the Error Inspector, I get three available fixes. The Merge fix allows me to select a feature to merge the error area (overlapping area) into:
Does the Merge fix work like this for you?
Scott
