Using Pro to access AGOL metadata
756
11-09-2023 06:54 AM
Tim_Rodaway
Using Pro, in the catalog view, I can access the metadata of an item within my organisation's portal, however once I add said item onto the map and try to view it as a content of my map, I get a message that the item cannot have metadata. The latter is a Layer whereas the former is a Feature Layer (Hosted), with the single Layer within it. There is some metadata (e.g. description) available on AGOL for the Layer itself, although most is stored on the Feature Layer. Is there a way of accessing the Layer's metadata from Pro, ideally with it linking back to the containing Feature Layer it was added from (i.e. to save having to duplicate data such as credits)? This seems to be the same across multiple items, opposed to being limited to just a specific item.
