Using Code for Field Calculation
1365
06-13-2024 12:11 PM
emoreno
Hi ESRI Community,
I am working on a project where I need to populate a new field, named Drop_Length_Total, in my layer named "DoubleD". Using calculate field, I've tried to write code to sum the shape_lengths of two lines, but am running into issues. The workflow i'm trying to achieve is below:
If the pink line touches the orange dot, i'd like the shape_length of the pink line to be added to the shape_length of the blue line that also instersects the orange dot. in the end I'd like for these sums to be written to the Drop_Length_Total field in my DoubleD layer. I've included a visual of what would need to be added together below, with the yellow being one summation and the green being another. If anyone has any ideas as to how I can better achieve this workflow, or any code I could test to calculate the field, it would be greatly appreciated. Thank you for any help!
pink lines = DTTERM layer
Orange dots = VSP layer
blue lines = DTTAP layer
blue dots = taps layer
Robert_LeClair
Esri Esteemed Contributor
Caveat, I used ChatGPT to write this Arcade expression based upon the statement - "Write an arcade expression that calculates a field called Drop_Length_Total in a layer called DoubleD where if a line layer called DTTERM touches a point layer called VSP, I'd like the shape_length of the DTTERM layer to be added to the shape_length of a layer called DTTAP that also intersects the same VSP point."
The script completed is as follows - haven't tested it as I don't have the same data as you:
// Initialize the total drop length variable
var dropLengthTotal = 0;
// Access the DTTERM layer
var dttermLayer = FeatureSetByName($map, "DTTERM");
// Access the DTTAP layer
var dttapLayer = FeatureSetByName($map, "DTTAP");
// Access the VSP points layer
var vspLayer = FeatureSetByName($map, "VSP");
// Loop through each VSP point
for (var vspPoint in vspLayer) {
// Find DTTERM lines that touch the current VSP point
var touchingDTTERM = Intersects(dttermLayer, vspPoint);
// Find DTTAP lines that intersect the same VSP point
var intersectingDTTAP = Intersects(dttapLayer, vspPoint);
// Initialize variables to hold lengths
var dttermLength = 0;
var dttapLength = 0;
// Sum the lengths of touching DTTERM lines
for (var line in touchingDTTERM) {
dttermLength += line.shape_length;
// Sum the lengths of intersecting DTTAP lines
for (var line in intersectingDTTAP) {
dttapLength += line.shape_length;
// Sum the lengths for the current VSP point
var totalLengthForVSP = dttermLength + dttapLength;
// Add to the total drop length
dropLengthTotal += totalLengthForVSP;
// Return the total drop length
return dropLengthTotal;
