Use Coordinates as Candidate in Address Rematch Pane?
446
07-31-2025 09:12 AM
DavidSolari
MVP Regular Contributor
When I rematch addresses I often have to bypass the geocoder entirely by hopping into Google Maps, grabbing the latitude & longitude and using that to place the address. As far as I can tell the only way to do this is to combine the Locate pane with the little "Pick from Map" cursor, which is imprecise and annoying. Is there a way to plug the coordinates I get from external services right into the rematch pane to get the exact location?
