Updating deep learning frameworks to new version
5289
13
11-03-2021 01:29 PM
MrG
Previously, I installed the deep learning frameworks on my workstation using the installer for Pro 2.6 (the installer provided by Esri that installs all the stuff, which is great!). It is up and running. and I could train models, infere and so on, without many problems.
The question is: I want to upgrade Pro to the last version compatible with the last deep learning frameworks installer. What strategy do you suggest? Upgrade first Pro and then uninstall the previous frameworks? Uninstall the previos frameworks before upgrading Pro? Upgrade Pro and then install the new frameworks on top of the old ones?
Any guidance about the order of installs and how to proceed will be appreciated. Thanks!!!
p.s.: for uninstalling the AI frameworks I suppose that the old installer has an uninstall procedure under programs >> uninstall, right?
DanPatterson
MVP Esteemed Contributor
@ShaunWalbridge might know if the Issues are actively monitored.  I suspect the release of Pro 2.9 may have impacted things.
... sort of retired...
MrG
Yes, I bear in mind to install 2.9 when they release the deep learning installer for 2.9
Probably the most secure proceeding is completely uninstall the deep learning frameworks for 2.6, then totally uninstall ArcGIS Pro 2.6. After having everything uninstalled (hope so) continue to install Pro 2.9 from scratch and then apply the deep learning frameworks installer afterwards.
Any guidance will be appreciated
DanPatterson
A clean uninstall is what I do with Pro being the first reinstall and supplementary installs after.
MrG
Thank you.
Just in case the Esri staff is listening, it would be great if the Deep Learning Frameworks installer could include the backbones for disconnected environments.
