Update ArcGIS Pro map after the feature service is updated
635
09-08-2022 12:25 PM
YinghongLi1
I have an ArcGIS Pro map which has a feature service loaded.  Then I updated feature layer names in the map which publishes the feature service.  I used  "Web Layer | Overwrite Web Layer" to update the feature service.  I checked the feature service in the portal and saw the new names for the feature layers.  However, the layers from the feature service in the ArcGIS Pro map did not get updated even though I used the Refresh button and did close/open ArcGIS Pro.  I had to remove the feature service and added it again to have the changes.  I'd like to know if there is a way in ArcGIS Pro that can load the changes without doing  remove/loading the feature service.
