Unit for tabulate area results in table?
6076
01-26-2024 04:09 AM
Labels (2)
EllaWes13
Hi!
So I use ArcGISPro on desktop and I used the tool "tabulate area" to calculate the amount of five different classes in a map. I got this table:
But what are the units in the table? Someone online said it's always square meters, another said it's pixels? Is there a way for me to check the unit or to convert whatever this is in ArcGIS Pro? Ultimately, I'd like the unit to be either square kilometers or hectares. The tabulate area was run on a satellite image of an area that had been classified into five classes using a training sample before.
Thanks for any and all help!
2 Solutions
DanPatterson
You should really interpret the results in light of what you specified in the tool and inputs to the tool.
There are many factors that will determine what the actual cell size is in the table
Tabulate Area (Spatial Analyst)—ArcGIS Pro | Documentation
It is a bit of a read, but you will have the answer once you establish the aforementioned
... sort of retired...
piiakoo
To my understanding, the units are the same as the units of the raster you calculated. The tool calculates the number of pixels within each value (or class in your case) and multiplies it with the pixel size.
For example, if I have a raster with 25 m pixels, the results of the Tabulate Area -tool are in m2. If I have 10 pixels with value 1, 20 pixels with value 2 and 30 pixels with value 3 within the zone features, then the results are:
Zone ID
Value 1Value 2Value 3
110 * 25m * 25m = 6250 m220 * 25m * 25m = 12500 m230 * 25m * 25m = 18750 m2
Note that this does not necessarily apply to other tools.
DanPatterson
EllaWes13
Thank you for this answer! The article you linked did help a lot!
piiakoo
Zone ID
EllaWes13
Thank you for this answer! Thanks for also showing some example calculations, it really helped seeing it to understand my results!
