Unable to use PDFATTACH command in Autodesk Civil 3D on PDF's exported from ArcGIS Pro 3.0
2460
08-05-2022 09:17 AM
by Anonymous User
Not applicable
I recently exported PDF exhibits from ArcGIS Pro 3.0. An engineering collogue used the PDFATTACH command in Civil 3D as he usually does to attach PDF. He found that the PDF's would not attach and Civil 3D gave no error messages.
PDF's exported from ArcGIS Pro prior to the 3.0 update and any other PDF's are able to be attached without any problems.
Any thoughts or advice would be greatly appreciated.
by Anonymous User
Not applicable
Thanks for that information. Our teams have tested the same workflow and were able to recreate the problem you are experiencing. We have found this is a bug related to our PDF export feature and are building a fix that will address this in the next patch for 3.0.
If you would like to subscribe to the public bug notice that will inform you of the update when it is released, head to this community post thread where you will be able to access this page   https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDE1MDU2NA==  and click the subscribe button for notifications.
by Anonymous User
Not applicable
Hi @Anonymous User,
Can you let us know which version of Civil 3D your colleague is using? We want to make sure we test this out on our side to verify if the problem is in the PDF export or if there is something else going on in Autodesk Civil 3D. Also, since this question is related to ArcGIS Pro and not ArcGIS GeoBIM, I am going to move this question into the Pro community where our teams there can help look into this.
Anthony
by Anonymous User
Not applicable
He is using Civil 3D 2020.
by Anonymous User
Not applicable
by Anonymous User
Not applicable
Great, thank you!
