Unable to resolve this mosaic dataset error
1849
01-27-2024 06:59 AM
ShubhamBhatia
Please help in solving this error:
The pixel type of the raster associated with the mosaic dataset item indicates that the raster's radiometric range might be too low for the pixel type defined for the mosaic dataset.
My mosaic dataset having some rasters out of which some are 8 bit unsigned while few are 16 bit unsigned and all of them having their value in between 0 to 259 range and that's why I have created my mosaic dataset in order of 16 bit unsigned but while analyzing it I am getting aforementioned error.
DanPatterson
MVP Esteemed Contributor
it is a warning and not an error according to
Mosaic Dataset Analyzer: Warning 71124—ArcGIS Pro | Documentation
and there is a suggestion too
... sort of retired...
ShubhamBhatia
Error - Drawing failure, error string = Failed to create an image cache tile for file_name at RD4E8C16DH0. [Missing raster: [E:\path\0990.jp2]]
Error - Failed to cache extent: 8498331.452073 3365681.202501 8531589.375026 3383720.399415 at scale 4513.98870499999975436367 ERROR 001456: Failed to update tiles. I have checked twice and file exists there and also I have set the value of maximum number of rasters per mosaic to 100
DanPatterson
So a new set of errors.  I suspect Tech Support is your next course of action.
