Unable to manualy edit raster table text
2473
08-05-2015 08:45 AM
MervynLotter
MVP Regular Contributor
Hi there
I am not sure if I am doing something wrong, but I unable to manually edit text in my raster's lookup table/value attribute table in ArcGIS Pro 1.1. Editing vector attribute tables works easy enough.  I have tried the tables Fields View to check that the field attribute table is not 'read only'.
By manually editing, I mean I try and click within the respective table to edit specific text.
My work around is that I am able to edit text using Calculate Filed on selected rows. Just seems a bit strange to be unable to edit the table as one was able to in ArcMap ... unless I am missing something?
I have tried both tif and img formats.
