Unable to edit versioned enterprise dataset (SQL version - 2012) in ArcGIS Pro 2.2 or 2.3 using active directory group.
1594
02-07-2019 01:57 PM
ClaireInbody1
Unable to edit versioned enterprise dataset (SQL version - 2012) in ArcGIS Pro 2.2 or 2.3 using active directory group. We are able to make edits to the version in Desktop 10.4.1 without issue. Has anyone run across this issue?
ClaireInbody1
We are told this is a bug. Can this be true? How can ArcGIS Pro 2.2 or 2.3 not have the ability to edit versioned datasets using an AD group???  BUG-000110487: Windows groups receive the error message, "Layer is ..
ThomasColson
This appears to be fixed at 2.3.2, which should be late march early april.
ClaireInbody1
Update: Desktop 10.4.1 works with active directory.
Desktop 10.5.1 does NOT work with active directory for versioning.
